Panamera 2010-Current
Brake upgrade
Old Oct 26, 2025 | 10:58 AM
boomin's Avatar
boomin
Default Brake upgrade
I have a 4S and I feel the brakes aren't good enough. To be fair, I daily a cayenne turbo with the PSCB's and they bite immediately. Porsche serviced it and stated they are perfectly fine. While waiting, I test drove a GTS and felt a better bite than the 4S's. I know I know but I won't trade it in Over seas I see they did a serious brake upgrade.
Anyone else upgrade the brakes? Or are there any options to look into?
thanks
Old Oct 26, 2025 | 04:48 PM
Mr Tee's Avatar
Mr Tee
Suppose you could try a set of turbo brakes ?
Old Oct 27, 2025 | 12:09 PM
GOR1LLA's Avatar
GOR1LLA
https://youtube.com/shorts/A0-0TaXn_...3Ewcqefy0nRtEO
thanks
what compound of brake are you running? semi metallic, ceramic, etc? Each pad will give a different feel, also based on how your rotors are, will also determine the "bite" your talking about. My PTT had semi metallic and I was not a fan ot those, I went to ceramic pads and the feel and "bite" feels a lot more responsive.
Old Oct 27, 2025 | 04:36 PM
Norge911's Avatar
Norge911
Have you tried a brake pad bed in procedure to remove some glacing?
If not, try that first.
Old Oct 28, 2025 | 04:32 PM
boomin's Avatar
boomin
Thanks guys
As far as I know, they're still original but looking forward to trying ceramic pads next.
I mentioned that suggestion of higher friction pads and managing tech said, "porsche's set up is the best".
I guess I'll get this done somewhere else 😀
Old Oct 29, 2025 | 09:15 AM
pbon's Avatar
pbon
Ceramic pads are unlikely to have better bite. They dust less, though, if that is a priority. Generally they have a lower performance rating than organic or metallic pads and are never recommended for track use because they can’t take the heat.
