Panamera 2010-Current
971 - Please help to identify sound
Old Oct 7, 2025 | 11:01 PM
jcarter90125's Avatar
jcarter90125
5th Gear
Default Please help to identify sound
Hello,
2018 Panamera 4 E Hybrid. 56k. Amazing condition with one exception. The hoot sound when the car shifts from 2-3 and sometimes 4-5. Video of the sound attached. I have read all the posts about the hoot sound on Rennlist and have not found a fix, or the real cause of the sound. Mechatronics unit was changed out 2 weeks ago. No change. The car is at the dealer now. Going on 4 weeks! They have no idea where the sound is coming from or why. I really need the help of a Porsche expert/mechanic who has heard this before. Please let me know! Thanks
Old Oct 7, 2025 | 11:16 PM
snzuloz's Avatar
snzuloz
Is there any chance that's an alarm for the speed? A setting on somehow? Very strange lol
Old Oct 7, 2025 | 11:27 PM
jcarter90125
5th Gear
No, I don't think so. So far from my research the suspects are:
PDK - clutch packs, or other internals
Turbo Exhaust valves?
That is really all I could find.
Old Oct 7, 2025 | 11:32 PM
snzuloz's Avatar
snzuloz
i've listened to it over and over, same noise both times and same duration as well. That speed warning is all that comes to mind lol
Old Oct 7, 2025 | 11:35 PM
jcarter90125
5th Gear
This is a much better video of the sound. The first video is too high pitched. My car sound like this:
File Type: mov
Old Oct 7, 2025 | 11:39 PM
jcarter90125
5th Gear
2 more examples of the sound. These are my car. Hard to drive and film!
File Type: mov
File Type: mov
Old Oct 8, 2025 | 12:07 AM
H2Owon's Avatar
H2Owon
I would look at the wastegate outlet plumbing. The noise is occuring when the turbo would be venting pressure at the shift.
Old Oct 8, 2025 | 11:48 AM
RussScott's Avatar
RussScott
Originally Posted by jcarter90125
Hello,
The sound appears to be coincidental with the drop of the tach needle. Unlike the digital speedo, the tach uses some hardware, including the needle. Something in that immediate system is all I can say.
Old Oct 8, 2025 | 04:51 PM
jcarter90125
5th Gear
I got the text today that they want to replace the PDK. I thought as much. Anyone else ever have this done??
Old Oct 9, 2025 | 09:36 AM
PSEE's Avatar
PSEE
Check things out over at the mcanforum.com - IIRC, there's a lengthy discussion of a hoot sound over there.
...wait... Here they are:
https://www.macanforum.com/threads/h...l-noise.76410/
https://www.macanforum.com/threads/h...d-noise.40114/
Old Oct 9, 2025 | 10:33 AM
Brick317's Avatar
Brick317
I have a 18 Turbo and with the transmission in manual mode it makes a similar hoot noise when upshifting during spirited drives. I've also noticed that the down shift from 4th to 3rd is a bit rough. It feels like there's not enough rpms during the rev match. I've resorted to lightly pressing the gas pedal when downshifting to bring the rpms up and avoid the jerkiness. Will have dealer check it out at next service.
Old Oct 10, 2025 | 12:00 PM
kjbetz26's Avatar
kjbetz26
4th Gear
I heard the exact same noise in my '18 4S and thought I was going crazy. It's a "hoot" like from an owl that occurs at slower speeds, typically when shifting from 2nd to 3rd. Should I be concerned about this turning into some kind of bigger problem? If not, I can live with the occasional hoot.
Old Oct 10, 2025 | 12:56 PM
Shuga's Avatar
Shuga
is it under CPO?
Old Oct 10, 2025 | 03:56 PM
Tim_Allison's Avatar
Tim_Allison
There are a lot of posts out there about this sound. My car has had it since I bought it in February 2024 and I've added around 12,000 miles on the ODO since then. One of my turbos was replaced under the emissions warranty and I've had my PDK fluid changed. The noise remains and I'm convinced it isn't harmful.
Old Oct 13, 2025 | 09:47 PM
djdonte's Avatar
djdonte
I have this sound on my 2018 4S. It doesnt happen all the time. I took it to the dealer and of course, they could not replicate it.
