Cannot remove Headlight
A few weeks ago I was replacing the 970 air filter with a Bmc unit. Was able to get the front bumper off and passenger side headlight popped out with the tool no problem. Unfortunately the drivers side headlight would not pop out with the tool. Was still able to get bumper off of course the upper bumper clips were missing too. Does the drivers side headlight have some additional fastener underneath or does the pop out mechanism get jammed up somewhere? It was quite lodged in there, tool no help.
The bmc air filter worked out great, it had a little better response on the throttle.
Same happened to me, I removed the wheel well liner and lubed up the area with WD and pushed along with the tool .
Seems like fine sand /grit gets in and can jam it up .Clean the area up well before replacement .
How often will you service the BMC filter ? Is it like a K&N ? I would be reluctant to deal with stuff like that in a Panamera ? Too much hassle.
