Panamera 2010-Current
Air suspension
Old Mar 13, 2025 | 03:21 PM
jamesf422's Avatar
jamesf422
Default Air suspension
2013 4S. Car sitting low. Not making any noise. Not going up or down. Think it is a relay or a fuse? When pressing up or down button it says NOT POSSIBLE. If it is a relay where would it be? Or a fuse? what do you think?
Old Mar 13, 2025 | 08:45 PM
RED HORSE's Avatar
RED HORSE
Good luck. Do you have any error messages on the dash? If not you may get by for only a couple of thousand $'s.
Old Mar 13, 2025 | 11:59 PM
Nosubstitute531's Avatar
Nosubstitute531
Both relay and fuse are in the back in the trunk. See below
that being said the relay doesn’t really just go bad unless the compressor was running non stop for a while and burned out the relay. Compressor usually runs non stop if there is a leak
Old Mar 14, 2025 | 12:01 AM
Nosubstitute531
I just went through this whole process with a help of a forum member so I’m happy to help in any way I can. Read the air suspension sticky at the top of the forum. It is golden and has a lot of good info.
Old Mar 14, 2025 | 10:46 AM
huskeric's Avatar
huskeric
Shawn is 100% correct... start with the fuses and relay in the back cargo area. Odds are, compressor(s) are looming in your future...
I can assist with a compressor swap...
Rick
Old Mar 14, 2025 | 11:11 AM
PSEE's Avatar
PSEE
IIRC, there a a couple of stickied threads at the top of this forum.
READ THOSE
And, as noted above, with a 2013 model year, there is s likelihood the compressor has reached the end of its service life.
Old Mar 14, 2025 | 11:46 AM
e30rapidic's Avatar
e30rapidic
Start with free/easy steps. Check fuses, then swap the relay with a known working one.
Old Mar 16, 2025 | 10:27 AM
jamesf422's Avatar
jamesf422
Thank you to all
