Panamera 2010-Current
Diagnostics advice needed
Old Oct 16, 2024 | 01:12 PM
Phil13's Avatar
Phil13
Default Diagnostics advice needed
Hi Guys,
I’m new to Porsche ownership and have spent a while going thru posts and getting used to it round here. Thank you for so much useful advice and tips!
I’ve had my 2010 Panamera Turbo for exactly a year now and have loved every second of it!
I’ve a few things I’ve had to do recently that came up as advisories at the MOT. Namely, new rear discs & pads and front drop link & lower ball joint which I’ve done myself thanks to the help from your various posts.
However, whilst it was in the garage I asked them to run a diagnostic and an absolute load of fault codes came up. I can’t work out what happened as the car is still running perfectly but maybe some of the small electric related jobs carried out in the past year might have contributed to the problem. I was wondering whether someone here could advise?
A year ago all was fine and I’ve only done 5000 miles since. However, during that time:
1 - The battery was drained flat by me stupidly leaving the ignition on for a few hours one evening. It was boost started by the AA.
2 - I’ve changed cornering bulbs on both sides.
3 - The near side rear passenger door doesn’t unlock which I believe is due to the actuator. However this does show up as a fault on the diagnostic list.
4 - The Stop/Start function works randomly but I deactivate it anyway. It’s always been like that since I got the car.
I don’t know if any of these affect the diagnostic system or need a reset afterwards or not?
If I got a mechanic to use a diagnostic tool, would resetting things be a good idea or a complete waste of time? I’m not used to how diagnostics work so any advice would be very helpful.
My theory is that once one thing pings up it affects others in a kind of knock-on effect.
Like I said, I find it difficult to believe that so many things could really have packed up when the car runs like a dream.
Any thoughts would be hugely appreciated.
Cheers, Hilton
Old Oct 16, 2024 | 02:20 PM
djdonte's Avatar
djdonte
Has your battery been replaced after it dying? If not, have it tested. A dying battery will cause a ton of random fault codes and electrical issues.
Old Oct 16, 2024 | 06:42 PM
Phil13's Avatar
Phil13
Thanks djdonte.
Good idea. Will check it before I do anything.
Cheers👍
Old Oct 17, 2024 | 03:45 AM
Marcus13190's Avatar
Marcus13190
You need to erase the fault codes and see if these faults come back
Old Oct 17, 2024 | 04:47 AM
Phil13's Avatar
Phil13
Thanks Marcus,
That makes perfect sense.
I’ll keep my fingers crossed! 😬🤞🏻
