970 GTS
970 GTS
Hello, I have a 13 Panamera GTS with code P0119. The Indy has replaced both temp sensor and wiring harness all OEM but the check engine light keeps returning. I also get the auto/start feature disabled even though I have it always on the off mode.
Now they’re recommending replacing the thermostat with water pump without a solid guarantee that this will remedy the issue.
anyone have experience with this?
thank you!
thank you!
I don't have a GTS but I do have a 970 and have experienced a similar issue, same code. Turned out to be the thermostat BUT the shop playing guessing games is a bit worrying. Perhaps check with another shop if you're able to?
zitro562 (Yesterday)
If the thermostat on your '13 Panamera is to be replaced, consider replacing the thermostat housing too. 970.1 models had tubes that were epoxied to the housing... verify if it is the case for your vehicle. For 2014+ model year, the thermostat housing was redesigned and tubes are now mechanically secured.
