Air suspension question...
#31
ABS actuation is unnecessary and not specified by Porsche for brake fluid replacement. Ditto for MB and BMW.
#32
Autel MaxiCom MK808BT Pro. I really like the blue tooth capability allowing me to work with the scanner outside the car. Bought from Amazon for ~ $450.
Also, as noted, my subscription has expired, but I still use without issue.
mrkim (06-11-2024)
#33
Also, did you install OEM or aftermarket parts? It's well known 'some' aftermarket parts are not the best made and could be defective or not up to par.
As such, I suggest using OEM reman'd struts, rebuilt OEM compressor, and OEM valve block. It's just too expensive to have to troubleshoot and then rebuy new parts once again.
Of course, there are many here that have had no issues, but just saying you have an issue somewhere and could be a bad 'new' part.
Lastly, it the level sensors are bad, it could surely cause issues too. Need to hook up a scanner and start collecting data.
mrkim (06-11-2024)
#34
I think that I have that on my list on Amazon or eBay.
mrkim (06-12-2024)
