Air suspension question...
curious to hear of your continued exploits... as you noted and are learning, the process for setting suspension height is far from straightforward and simple. My left rear is still in need of some final adjustments, but fear doing this as it will - at least in my case - turn into another two-day journey. and in the end, be about the same as it currently is... this is surely not for the perfectionists out there!!!
But will keep everyone updated on this little hopefully stays little adventure.
chassis (06-06-2024)
mrkim (06-07-2024)
I don't want to keep borrowing my friend's or anyone else scanner so I may have to invest in getting one. Which is not bad of an investment honestly.
mrkim (06-07-2024)
Update on my suspension...
So while waiting for my new leveling sensor, I cleaned the joints on the linkages, and carefully sprayed some WD40 on to them, then pushed in the connection and the wires as much as I could. My thoughts were, the fault codes saying that there is a "short" may be due to the linkage not moving freely as before. Yesterday I drove around so far nothing, but will still replace it once the new sensor arrives just to be safe.
mrkim (06-07-2024)
Autel is disparaged on this site for lack of transparency of required expensive subscriptions.
iCarsoft is a great tool, I use it for regular maintenance and diagnostics on my .1 9Y0 Cayenne S.
I can't say much on iCarsoft don't really know much people with that. Majority of my mechanic friends have Autel.. but I am curious about it. Like trying Japanese flan vs Mexican/Spanish flan... I'm willing to try.
Yes, one must be very careful when purchasing an Autel scanner as they don't mention the need for mandatory updates for some newer model vehicles. My Autel continues to work fine on my '15 PTS after the subscription expired, but need to be aware this may not be in all cases. Also, I do have a PIWIS 3, but find the Autel operating system to be much faster and easier to scan/clear codes.
As a current owner of the Icarsoft POR 2 and POR 3 with current updates, neither has the ability to flush ABS brakes on either a 991.1 or 971 even though the literature says it will. I would avoid the brand.
mrkim (06-07-2024)
Oh wow 😳, I was looking through my buddy's Autel scanner looks like it has those capabilities.
The iCarsoft has the flush ABS function displayed as available, it just doesn't work. It gives you an error something like "this function is not available" when you try to use it. Gave the same error on both cars. The learning here is that you get what you pay for.
mrkim (06-07-2024)
