Code P1026
I greatly appreciate any help!!!!!
I believe that inspecting or replacing the fuel pressure sensor beneath the intake manifold could be a reasonable course of action.The P1026 code appears to be related to fuel-specific issues. Considering that I have already replaced the high-pressure fuel pump and cam plug, the remaining fuel-related components would be the pressure sensor under the intake and the low-pressure in-tank pump and filter.
As for air filters etc, I think that would be a gradual issue and not an overnight problem.
The car just turned 50k and have never had a single issue until this.
That suggests to me that either you really do have below-spec pressure in the high pressure rail, or the sensor that monitors it is faulty.
You might find this useful:
https://rennlist.com/forums/cayenne-...1031-help.html
One of the things that thread mentions is that fuel pressure output of the high pressure pump is dependent on pressure output of the "pre-delivery" system - the pump, lines and filter that carry the fuel from the tank to the engine bay. What I would do is try to get some more data, first from the high pressure rail sensor, and then also from the low pressure system. There should be a spec for the pressure in the low pressure system - something like 30-50 PSI I'd guess. If that checks out, then you go after the high pressure system, but if it's low, and the high pressure system also has low pressure, then you can strongly suspect that your problem is on the low pressure side.
This eliminated code P1031, but I still have code P1026 and same driving symptoms.
I decided to take it to a euro shop to have diagnostics performed. I told them I just replaced the HPFP with an aftermarket unit. They asked if I replaced the fuel pressure sensor which I did not.
After "testing", they said all their testing leads them back to the HPFP that I just replaced. Said they do not put on anything but factory new pumps. They said they can see spikes and dips in fuel pressure.
Quoted 2800 for pump, fuel pressure sensor & labor. Said they always replace the sensor when they replace the HPFP (thats not reassuring that they actually pinpointed the issue....more like lets make sure we cover all the basis with new parts while we are in there)
I'm more than capable of replacing the parts......but..
How do I know what they're saying is fact? Unfortunately its hard to trust anyone these days.
