971 ST suspension
971 ST suspension
Hi. I have handling issues. Car is very bouncy. I suspect it’s due to the recall on the. suspension. However everything is working as it should and confirmed no leaks etc. I have recently driven newer cars and whilst they move about the suspension is a lot flatter and doesn’t have as much lean in the corners. I thought one of the benefits of air suspension is that it doesn’t age. It either works or it doesn’t. Before I start replacing things anyone else have any experience of this and how it was resolved ? Many thanks.
2017 65000 miles e hybrid
Probably not suspension but more likely a tire or tire pressure or alignment. I would start changing tire pressure, then have shop check alignment and while in shop look over the suspension.
May also consider changing tire if not new or change to summer tire vs all season
Hi. Tires are Pirellis all round and tried manufacture spec and slightly less in terms of air pressure. It’s suspension related. You can see and feel the car moving up and down. I suspect it’s the suspension recoil is not as stiff as it should be. Sport mode will make the suspension harder but doesn’t take away the bounce. Is there any other components that could be causing this ? Electric sway bars etc ? Don’t want to start replacing air shocks if they alll appear to be in good order with no obvious faults.
Worn or damaged control arms and bushings can affect the stability and handling of your car.
If the suspension struts or their mounts are worn or damaged, they may not provide the necessary support and damping, causing a bouncy ride.
Also, the suspension linkage, including sway bars and end links, helps keep your car stable when turning corners by controlling how much it leans. If any of these parts are old or broken, they could be causing the problems you're having.
Thanks all. I have owned the car for almost 2 years and it’s been like this from the start. Everyone who looks at it concludes the air suspension must be fine as there are no errors or codes and everything is working as it should.
In a renewed quest to get to the bottom of things I have noticed if I lift the car and then lower again everything is significantly stiffer with less bounce. I assume this is because there js more pressure in the system following the increase in height. I think this is worth a further explore.
Acknowledge point regarding potentially worn suspension parts and will get them specially looked at / replaced also. Car is under warranty and has just had 60K service so suspect anything obvious would have been flagged. Any other suggestions welcomed.
Crawl under the car with a pry bar and see if the rubber control arm bushings in the front suspension (4 of them) are worn or torn. Use a bright LED flashlight to help look closely at the bushings.
