2013 4S service
2013 4S. 98,000 miles owner said never did a thing to it.
Change oil only.
Have all record oil changes.Every 5k.
What services need to be done?
Says PDK on the steering wheel. Should be changed?
Change oil only.
Just purchased a 2011 Turbo 99k - so here's my list In order i hope to complete them.
Transmission oil/pan/filter (pan has a slight leak from the seal so get that taken care of)
Plugs/coils - about due anyway
Oil - only has 2k on the current oil but ill just do it so i know.
Front drivers side CV axel as boot is leaking slightly
probably should replace coolant and brake fluid.
When the air suspension starts to fail
Upper and lower control arms sway bar bushings, tie rods.
as well as replacing which ever air spring goes out next. (probably drivers side as passenger was replaced in 2019)
Anything beyond those things I'll probably take to an Independent
hopefully just going to DIY it - It's CPO warranty expired in 2019.
I also forgot to mention I'll be replacing the transmission mount while changing the transmission Oil
https://www.youtube.com/@TomorrowsTek
https://www.youtube.com/@mikeshorsepowergarage7577
couple of decent how to channels on Panamera's
brake fluid replacement
engine air filter replacement
cabin filter replacement
coolant replacement
wipers replacement
spark plugs replacement
ignition coils replacement
Gummi Pflege all door and liftgate seals
Check sliding roof drains for flow/absence of blockage
