Hi guy's, i've panamera my2012 and when i'm inside the car and when i open my door i want that all doors was open and not only my door.
Can i modify with piwis 3 ?
Thanks.
Good day.
Marc
Thank's for your answer, but sorry you picture is when i unlock the car with remote control but when i open the door when i'm inside only driver door is unlocked and not all doors.
Marc
Big difference ! Now when i open my door to go out and if i want open trunk or rear door it's impossible, i need to push on button unlock after and it's necessary return in the car !!
strange, because mine behaves exactly like you want yours to when unlocking/opening the drivers door already. My key is in a leather case, so I never press buttons on my remote.
you should check the settings in the PCM menu to see, but remember to save them to menu before turning the ignition back off.
No my doors don't unlock when i open driver door from inside only.
If engine is off it's ok but when contact is on it's impossible. I need to push button lock/unlock.
I think it's a security problem but i don't agree with this function and i will want change it.
ok, I understand now. It’s only when the car is already running. That would be a security feature to keep criminals from jumping in your car. Here in the US, that’s a real thing to worry about in some areas.
maybe PIWIS 3 could code that change… I don’t know
Your other option would be to press the central locking button before you get out of the car
Yes it's the solution but when i'lm outside car and i want open rear door i need return inside and push on button, not easy !
I've looking for on piwis but nothing.
I believe the feature you’re talking about is when you put the car in “P”, while the engine is still running and all the doors are unlocked when it’s in “P”. This is set via PIWIS. I have a 971 and a Q7 that came with this feature and I hated it. I wanted the doors to remain “locked” when I shifted to “P”. I changed that via PIWIS, very happy now.
