Panamera 2010-Current
Panamera 971 Hybrid wont start
Old Jan 9, 2024 | 10:27 AM
gogetit's Avatar
gogetit
Default Panamera 971 Hybrid wont start
Hello,
i bought a crashed Panamera 4S 971 2022 year, only radiators, one of headlights are broken and one of the curtain are open. Some of the modules was stored crash, i reset it in a couple of modules, but i cant reset it in the high voltage battery module. Also in the high voltage battery is stores fault for additional coolant pump activation open circuit. 8l8 checked the cable to the pump are ok, fuse is ok, tried to change the relay, but the result is the same.
is there pyro fuse for the high voltage system ?
I changed the pyro fuse for the 12V.
I will be so grateful if anyone can help me !
Old Nov 4, 2024 | 03:24 PM
ct14's Avatar
ct14
The HV battery has a fuse inside. Likely it's blown.
Old Nov 10, 2024 | 03:07 PM
mike23021's Avatar
mike23021
2nd Gear
Hey @gogetit , did you managed to fix your car ? I bought a crashed panamera 4 ehybrid and I have the same problems. Car in E Hold and cannot change the driving mode, cannot start the petrol engine and I have no response from the EV. I'm thinking to take the EV battery out and check for the power fuse.
Old Nov 10, 2024 | 03:08 PM
ct14's Avatar
ct14
What are the fault codes??
Old Nov 10, 2024 | 03:24 PM
mike23021's Avatar
mike23021
2nd Gear
I don't have the gratest diagnose but looks like I have no comunication with the Electric Drive module - Status Cannot be reached and in the dashboard I have Engine control fault error.
