E-hybrid 4 vs 4S differences/upgrade?
now the brakes, I suppose, is easier? I’m sure I could fit the ginormous 10-piston 420mm turbo brake but it’s likely need bigger brake cylinders. It seems the 4S has 410mm 6-piston brakes and the 4 hybrid has 390mm front brakes right? I read somewhere that the Sport Turismo has bigger discs? Is there any problem with a simple mechanical swap for the 410mm discs? Does the software needs to be told?
i remember reading wider tires also and ofcourse the tuned. so other then that it is the same,. it is just way porsche trying to sell more trims to fit people budget. Let me know if the rotor fit, cause i remember the 390mm is pretty pricy.
