ARMASPEED Carbon Fiber Cold Air Intake
Basic Sponsor
Introducing the Porsche Panamera ARMASPEED Carbon Fiber Cold Air Intake
Carbon fiber air intake for PORSCHE Panamera 3.6 V6/ 4.8 V8
Direct bolt-on design, no modification needed
No remapping of ECU/DME needed
Gloss Finish
Gloss Finish
- Carbon fiber airbox
- Carbon fiber inlet pipe
- ARMASPEED high flow air filter x2
- Accessories
The following 2 users liked this post by x X CLoud X x:
Jasonbourne8642 (01-13-2024),
MKC91 (12-12-2023)
The following 2 users liked this post by Shuga:
MKC91 (12-12-2023)
Seems like there is no discussion or sharing ? I was considering to buy one.
I would also like to know if it can be swapped out without removing the bumper ?
Does it give any gain on performance in the lower side 0-100kph ?
How does it sound ?
How does it sound ?
Basic Sponsor
I have one for sale
you do have to remove bumper BUT I’ve found a super easy way to remove the bumper without taking out the wheel liner. It takes me 10 minutes by myself to remove bumper.
Last edited by mattbarrett10; 03-29-2024 at 01:09 AM. Reason: I no longer want to post this
How??
make that make sense please. How could it lose Power?? It’s a full carbon cold air intake where the heads sit lower then stock where it can get way more airflow.. soo instead of each side going into 1 air box stock.. you now have better position with 2 huge intakes to bring a lot more air.. soo by your logic.. more airflow would lose power?? Ok got it..
I do it all the time. There’s only 1 screw needed to be removed on each side. You only remove 1 screw from the fender liner to expose the 1 screw holding up the bumper. Do that each side.. I also only have 2 screws holding up the under carriage tray to the bumper.. you really only need the 1 main center screw to hold the underside of bumper.
This is the screw to remove 1st. Then you’ll see the screw holding the bumper..
