Panamera 2010-Current
SURVEY: Panamera 971 Vibration
Old 03-22-2024 | 11:21 AM
  #31
v1024's Avatar
v1024
8th Gear
Do you mean the brake disc rotors? Not sure they have checked it. They are ceramic so I was under the assumption that would not be a problem. No vibration at all when braking by the way. But thnx, I will get that checked!
Old 03-22-2024 | 11:38 AM
  #32
sac02's Avatar
sac02
Originally Posted by Marcus13190
It's possible that is the front hub. Have you controled the flatness on the rotor and without rotor ?
I think Marcus was saying to check hub runout with and without rotor. As in check runout at the hub itself, and then mount rotor and check runout again on the rotor.
You are correct that carbon ceramics are much less likely to have defects. but nothing is ever truly perfect.
Old 03-22-2024 | 02:48 PM
  #33
Marcus13190's Avatar
Marcus13190
Yes, sorry for my langage !
Old 03-25-2024 | 03:06 PM
  #34
v1024's Avatar
v1024
8th Gear
Thanx guys. But I was wondering, for an inbalance in the rotor and / or Hub there has to be a (or change) in vibration during braking? Because there is non while braking. The main vibration is in the gaspedal en the rest pedal plate and increases when lowingering and stiffening the suspension.
Old 03-25-2024 | 04:07 PM
  #35
Mootz's Avatar
Mootz
My rotors have been replaced with absolutely no change in vibration.
Are you feeling the vibration all the time at same speed or is is there sometimes and not others?
Old 03-26-2024 | 08:02 AM
  #36
Marcus13190
Control yours fronts shafts.
Old 03-26-2024 | 09:52 AM
  #37
v1024's Avatar
v1024
8th Gear
The vibration is almost there at all speeds
Old 03-26-2024 | 10:47 AM
  #38
Marcus13190
Ok possible it's engine mount problem
Old 03-26-2024 | 11:21 PM
  #39
Norge911's Avatar
Norge911
Thanks for helping Marcus but there is a bulletin on the connecting shaft. None on the axles but mine were checked and cardan shaft replaced. No change.
this is not the issue.
regarding your other comment to check hub run out is very valid. I also think the bearing going through the carrier unit on left axle could be a culprit. Note, BGB ran car on lift and could validate the vibration on a lift.
Old 03-26-2024 | 11:30 PM
  #40
Norge911's Avatar
Norge911
Porsche North Houston have had about a handful of cases. First case was their owner with brand new Panamera, they could never figure it out and car was sold.
Old 03-27-2024 | 01:36 AM
  #41
healthnut76's Avatar
healthnut76
2018 Panamera Turbo Sport Turismo
36k miles
Like others, vibration between ~53-62 mph
Weirdest thing, this didn't start to happen until after I recently swapped out Michelin PS4Ss for Michelin AS4s and had it aligned. The vibration is mild, but detectable. So, not sure if it's tire/wheel runout or what. 🤷‍♂️
Old 03-27-2024 | 06:58 AM
  #42
Marcus13190
On Porsche Cayenne, central shaft have problem. It's possible that Panamera have the same problem.
Old 03-27-2024 | 02:41 PM
  #43
jbkanas's Avatar
jbkanas
Default 971 Vibration
Originally Posted by Mootz
Numerous Panamera 971 owners have reported experiencing vibrations at highway speeds, particularly around 57mph. If you're facing this issue, you can find more details and join the discussion in the "CPO issues, what to do?" thread on Rennlist: https://rennlist.com/forums/panamera...hat-to-do.html
2022 Panamera 4 Sport Turismo eHybrid
4-wheel Steering
Air Suspension
20" wheels
23K Mi
No vibrations at all. I did have an unsettling vibration last week at around 50mph; Determined to be glob of snow stuck in LR wheel. Removed snow, no more vibration.
Last edited by jbkanas; 03-27-2024 at 03:57 PM. Reason: Update Panamera configuration
Old 03-27-2024 | 07:17 PM
  #44
capuman's Avatar
capuman
  • End of 2022
  • 4 Ehybrid
  • 25000
  • No vibration at any speed ever experienced
Old 03-27-2024 | 11:02 PM
  #45
Mootz's Avatar
Mootz
What I can't get my head around is that I travel to work on the same road every day, same speeds, and some days the vibration is hardly noticeable, yet on others it's so bad it's almost comical! Doesn't correlate to temperature or weather either.
Quick Reply: SURVEY: Panamera 971 Vibration
