Hi all 👋 this is my first post here. I’ve spent a few hours researching this topic but haven’t found any definitive answers.
I have a 971 Panamera 4 with the standard brakes. I’m looking to find some 19’s for winter tires and I found a good deal on some used 19s from a 970 Turbo S part# 97036215800. Has anyone been able to verify these fit well?
The wheels are differents between front and rear. You want install the same ?
The 970 size are : 9x19 ET60 (front) 10x19 ET61 (rear) 97036215800 (front) 97036216000 (rear)
The 971 size are : 9x19 ET64 (front) 10.5x19 ET62 (rear) 971601025A (front) 971601025G (rear)
Thank you! I should have posted both part numbers! I do intend to stick with the staggered design. The offsets look pretty close if I’m understanding this correctly. 🤔
Similar question. Has anyone mounted 20" classic Mag Wheels
9.5x20 ET 63 front
11.5/20 ET 65 rear
on a 971? The OEM 971 wheels are
9.5x20 ET 71 front
11.5x20 ET 68 rear
It's for a summer tire on a hybrid ST. I have separate 19s mounted with snow tires for winter. I can find takeoffs in the 970 offset for half the price of 971 takeoffs. I have newish 20" tires but the factory 20" wheels were all bent beyond repair when I did a road force balance.
