Hey guys,
My Pana 2011 has PSM failure on dashboard time to time. After restart fault gone. When connect Icarsoft Cr pro tester I can see actual value of steering angle which looks very strange: while turning left the angle is rising normally from 0 degree, but when turning right angle jumping after 0 to 6556 degree and than dropping down with turning. Don't know if it is steering sensor issue or Icarsoft soft not compatibility. Steering angle calibration doesn't help. I wondering if anyone had it before?
I think you have problem with sensor
With icarsoft you can see values of this sensor.
What's your panamera model ?
Have you make calibration of this sensor ?
This sensor is here. I think you need to buy this réf 97061304501
Hi.
My Panamera 4 is 3,6 2011. I did sensor calibration few times and has been successful but value of angle stay the same: left normal, right begin from 2556 degree.
After about 100km PSM failure come always with: C120A1 - control unit fault center - differential lock 002085 - sport mode, center - differential lock, faulty 00208A - sport mode, faulty
C12019 - communication with air conditioner regulator
and check transmission and engine for faults, but they are clean.
There is no any faults about steering sensor, only strange value of angle with I can see in Icarsoft what I suppose can be root cause of PSM problems.
All ideas will be welcome. Thanks!
