Panamera 970 Rear Seat Removal
Hello Everyone,
I'm a new Panamera owner. I need to inspect the fuel filter because I am getting a fuel smell. Does anyone know how to remove the lower rear seats on a 2013 Panamera GTS? Thanks!
Marcus13190 thank you for sharing the diagram. I had given this a try but I was unsuccessful. Have you tried this on your vehicle or know of anyone who was successful doing it this way?
Sorry to revive a slightly old thread, but I have a similar issue. How to remove the bottom rear seat cushion. My 970 4S is 2010. I have seen the diagram listed in this thread a few times, but my seat connections or installation does not look like those shown. There are no slots or anything I can see to insert a screwdriver. The connections on the floor lok different than those shown. That diagram also shows adjustments for moving the seat and the lumbar adjust button, my seats do not have those adjustments, maybe it matters.....
My seat belt anchor probably needs to be replaced, so I need to get to that item by removing the seat. I suspect my daughter dropped candy or something into the seat belt anchor! Really appreciate if anyone has ideas, or knows how to get that seat cushion out....
Thanks, Lou/Squareloop
You need to buy newers clips and after, you need to break old clips. I don't find good technic to remove these clips. I don't know if there is a tool for these
