Panamera 4E Sport Tourismo 971 2018 21 inch wheels handling problems
so just done the change to 36 psi on both front tires and this made quite the difference I must say.
don’t get me wrong in Finland you can see the roads that are worn out by winter stud tires and I still get moved around in them with the wide Porsche wheels but the front definitely felt more predictable on normal flat road this time.
tire age is late 2019 on the rear and late 2020 on the front from the tire date codes.
I think I will be ok for now after the front pressure drop thanks for that idea I usually drop front and back at the same time.
rossba (04-16-2023)
I have similar set up and have experienced the same. Wheel alignment helped with the general wondering of the car but was still getting the car skipping and jumping around. Was recommended to lower the pressures and similar to above made a marked difference and cured the jumping and shuffling.
in terms of pressures I suspect I was over inflating. Porsche recommend normal pressures based on 20 deg Celsius. I am in the UK and don’t often see these temperatures since lowering my TPMS is now showing values in line with recommended pressures
rossba (04-18-2023)
