Porsche panamera control unit failures?
Hello, my older 2018 Panamera 4E is having multiple error codes, some of which are very concerning, but the computer doesn’t see them as issues. Let me say this first: ride quality, 0-60 acceleration, and pure electric range (27 miles) are all within or above the manufacturer's specifications (0-60 acceleration is actually faster than documented). However, here's the catch: I got a hybrid CAN bus fault and no communication at the same time, as well as multiple electrical malfunctions on the headlights and infotainment. There's a control unit internal fault on the DME, cell voltage deviation above limit values on the hybrid battery pack, and one issue that I can definitely rule out, yet it reports as a currently active issue: "Front left mid-range speaker - open circuit." To my knowledge, this is saying either the speaker is blown or the wiring has broken, yet there’s voltage going to the speaker, and it's outputting sound normally with zero scratch noises. Not to mention, this car likes to cut power steering at random times, and sometimes the car will say something like "power steering fault driving permitted," yet it’s impossible to turn the wheel at a standstill. Sometimes the car won’t recognize any issues with the power steering, yet there's no power steering, and even when I plug in an OBD2 scanner, it still sees zero issues. Oh, not to mention, the rear wing lost its calibration, but luckily, I was able to recalibrate it using my OBD2 scanner. Right now, I’m confused about what's wrong. It's a cascade of failures, yet some systems are working fine while others aren't with no errors. If someone can direct me to something that might not even fix it but is worth trying, please let me know.
(edit) this car has already had 13k dropped on repairs from Porsche techs for broken ground cables wire harnesses and hybrid charging port that short circuited from water damage according to Porsche… |
Holy Jesus. Sorry for your troubles...I'm sorry I'm no help. Just passing condolences.
Originally Posted by love my 4s E
(Post 18714304)
Originally Posted by ZedZed
(Post 18715976)
ICBW, but aren't OBDII codes limited to engine only?
