Need Help - Major AC Problem
I have a 2016 Panamera Edition, and a 2017 Macan GTS. The Panamera AC blower was dead. I searched everything I could for Panamera (2010-2016) and there just isn't much user/DIY info on these cars, apparently Panamera owners don't like to get their hands dirty.
So blower no worky. I replaced it with a Nissens blower (identical), and replaced the resistor "control" pack above it while I was at it, and also replaced cabin filter and vacuumed the intake vent under the hood. Checked all fuses that could be related (esp 5 and 57 on left side), with meter, and they're all GOOD. Put it all back together, and still no worky. Still completely dead.
Got out my iCarsoft OBDII reader for Porsche, and I don't see any error codes that are significant, except for one that says something about "fan control = blocked". No idea what that's trying to tell me. All the controls work fine, I checked the activity of most of the buttons on the console with the analyzer, no problems.
Anyone have a similar problem before? i hate to be at the mercy of the dealer to analyze this problem. WHERE is the actual logical control for the HVAC system done? Is there a module somewhere? There is no blower fan relay in this car, per the research I've been able to do.
TIA for any help you can provide.
Jerry
Jerry
Yesterday I took the car to Porsche of South Orlando, and they wanted $800 (only 2 hours time @ 400/hr) to diagnose, plus an approval from me that they could take more than 2 hours. This is just to diagnose, not even to fix it.
Hello all,
thank you for your help in advance. I have 2012 porsche panamera base model. AC blow all hot air refilled freon checked no leak what so ever still doesn't work. local mechanic replaced ac compressor still doesn't work.
check voltage to ac pressure switch got 12Volt then attempt by passed pressure switch by jumper now no voltage to pressure switch and no AC. replace pressure switch still same problem. NO AC
does anyone know where is AC presure switch fuse and replay locate?
Thank you
Thank you
