Panamera 2010-Current
Exhaust valve controller
Old Mar 17, 2023 | 02:48 PM
JamesP13RRN's Avatar
JamesP13RRN
Default Exhaust valve controller
Hi all,
does anyone know what the voltage should be at the controller behind rear bumper when sports exhaust button is pressed? I have 0.5 and O volts when off.
I ask because I have just fitted a new controller and my flaps still do not work. I have new actuators and both work when linking vacuum hose together (by passing solonoid controller at back bumper) also have good vacuum.
The only thing I can think of is the new controller is faulty or button isn’t triggering something else I’m missing? It lights up.
2013 GTS Pan
cheers
james
Old Mar 17, 2023 | 06:07 PM
JamesP13RRN
I don’t have 12v at the PSE valve controller is there a relay or control unit somewhere?
done lots of reading but can’t seem to find anything on why there wouldn’t be 12v there?
Old Mar 25, 2023 | 09:03 AM
JamesP13RRN
Update I only have 0.5v coming out of the rear BCM when the button is pressed.
not a coding issue otherwise button wouldn’t light up.
does anyone know what I can test going into the rear BCM? Everything else works..
Old Mar 26, 2023 | 01:45 PM
Marcus13190's Avatar
Marcus13190
Hi, when there is no voltage on the connector the valve is open. When the button is not active the voltage is 12V.
Old Mar 26, 2023 | 03:03 PM
JamesP13RRN
He mate thanks for the reply. So I don’t have 12v at all.. fuses are all good?
Old Mar 27, 2023 | 03:43 AM
Marcus13190
If you don't have voltage you need to control fuses, ithink
Old Mar 27, 2023 | 04:01 AM
JamesP13RRN
Pardon? Control fuses?
Old Mar 27, 2023 | 04:33 AM
Marcus13190
Yes if you don't have voltage first you need control the fuses
Old Mar 27, 2023 | 04:39 AM
JamesP13RRN
All the fuses are ok mate I’ve checked everyone of them and the B2 fuse in the boot that controls the flaps.
that’s where im at a loss
Old Mar 27, 2023 | 04:56 AM
Marcus13190
I think that the problem is module that control the valves. It's locate rear under car.
Your valves is always open ? If yes the problem is this part : 7PP906270
Old Mar 27, 2023 | 05:10 AM
JamesP13RRN
Your missing the point Marcus I have a new valve. I don’t have 12v to the valve…
Old Mar 27, 2023 | 05:14 AM
Marcus13190
You need to control if you have 12V or ground on the connector.
Old Mar 27, 2023 | 11:55 AM
Marcus13190
To test you locate rear BCM in the trunk near battery. You have grey connector (42 pins). On position 5 there is wire black/yellow that command valves. You can test it.
If you don't have voltage it's a BCM problem and you need reinitialize the BCM with a Piwis
Old Mar 27, 2023 | 12:25 PM
JamesP13RRN
Hi Marcus, Yer just tested the BLK/YEL and its 0.5v so im thinking the BCM is goosed but only on this pin out as everything else works off that rear BCM. Weird.
Do you think a PIWIS will solve it? I have it booked in with porsche £220 just for them to tell me its faulty. I may cancel the appointment but i cant see another way of sorting this. I can buy a rear BCM off ebay but im guessing it will need coding to car?
Old Mar 27, 2023 | 12:52 PM
Marcus13190
To change BCM it's necessary have Piwis.
