Panamera 2010-Current
Panamera 4 970 rear console vent replacement
Old Feb 20, 2023 | 05:53 PM
3Danim8r's Avatar
3Danim8r
Default Panamera 4 970 rear console vent replacement
So, my new to me 2011 Panamera 4 has some broken/missing vent blades on left vent. I purchased a replacement vent, but wanted to see if someone has done this before. It looks like I need to remove the center Seat Heater/Door Lock switch that sits between the two console vents, to access the two bolts that are holding the vent in place. Does it snap out? or are there clips that I need to push/pull first? Didn't want to break anything trying to remove it, and can't find anything on the Web that shows the process or a diagram of the parts. Any thoughts/suggestions would be appreciated.
Old Feb 21, 2023 | 12:13 AM
Deezflip's Avatar
Deezflip
I've removed it before using this guide, scroll to the bottom of it...
https://www.insanegarage.com/diy-air...sche-panamera/
Unfortunately I didn't take pictures along the way.
You would need to pry that center plate/cover. Just take your time
Old Feb 21, 2023 | 04:52 AM
3Danim8r's Avatar
3Danim8r
Thanks! That diagram/instructions was what I was looking for. Wish it would've given an indication on what sort of 'clips' are holding the two faceplates that need to be removed. Well, here's hoping nothing snaps/breaks. I'll comment on here after I undertake the job later this week so others can benefit as well. Again, thanks!
Old Feb 21, 2023 | 01:58 PM
Deezflip's Avatar
Deezflip
The clips on these cars are impeccable and very secure. I assume that's why it's the best among other cars as for minimizing panel creaks and rattles.
If you have any, use those interior plastic/composite pry tools until you can get a finger in to help pry them out. The trick is not to stay on one area and have too much bending and flex when prying it out on a single side. If you get one side out a bit, balance it out and start prying out on the other areas.
If you need to get an idea of what the clips looks like...remove the wood trim(yours may be a different finish) above the glove box. It's probably the easiest thing I was able to pry out on this car. It has the same clips for most of the trim and panels of the car.
Old Feb 21, 2023 | 01:59 PM
3Danim8r's Avatar
3Danim8r
Good idea. Thanks.
Old Feb 22, 2023 | 04:23 PM
sac02's Avatar
sac02
This is the correct answer, I was literally going to say the exact same thing down to the glovebox trim.
Old May 6, 2024 | 09:55 PM
charlieamico's Avatar
charlieamico
2nd Gear
Default How easy was the cover removal?
I have the same issue at rear center console left vent, seen the website which was amazing diagram, but doesn’t show exactly how to remove that center cover in order to get to remove the screw for vent cover, any tips u can throw my way, would be greatly appreciated, thanks!
Old May 6, 2024 | 10:54 PM
Deezflip's Avatar
Deezflip
I started from the top which allowed the most flex. Get a flat pry tool and get it as close as to the top tab as possible without over flexing the cover, you should feel the pry tool reach it. That's where you would pry and prevent the plate cover from over flexing.
Old May 7, 2024 | 08:06 AM
charlieamico
2nd Gear
Thanks for the quick reply, you made my day with that detailed instructions, thanks!!
