2014 Panamera S E hybrid Hybrid park vehicle safely!
5th Gear
Hello,
I am getting a red fault error - Hybrid park vehicle safely
I checked the error codes using icarsoft device and have many errors that I cannot find details on.
When I connect the hybrid charger, it won't let it charge with solid red light near a charger. After clearing DTC errors, it does turn to solid green but nothing happens after that.
There are the error codes I notice :
P33F100 - 00AA96
P0A7D00 - 00AA9D High-voltage battery – state of charge (SOC) too low
P0A1F00 - 00A850
P0AA400 - 00Aa87 MINUS - Executor does not open
P0DAB00 - 00Aa8B
P00305f
P162400
U14D400
U14D300
Any way to get the HV charged?
P33F100 - 00AA96
P0A1F00 - 00A850
P0DAB00 - 00Aa8B
P00305f
P162400
U14D400
U14D300
Will it let you recharge while you are driving? If so, then maybe the problem is with the charger or that part of the system. If not, then it is something more general.
Just an idea ...
Nat
Just an idea ...
Nat
5th Gear
https://www.obd-codes.com/p0a7d
Causes for this code may include:
From this it sounds like a trip to the dealer is in your near future
- Defective HV battery, cell, or battery pack
- Bad alternator, turbine, or generator
- HVBMS sensor failure
- HV battery pack fans not working properly
- Loose, broken, or corroded busbar connectors or cables
5th Gear
Thank you all. For now, I am able to fix the situation and able to get the car started.
I used some heaters around the battery to get the temperature up(8c) and used icarsoft to clear the DTC for the High voltage battery which allowed the charger ( the light became green ), I kept looking into a data stream and was able to get SOC to 7% by repeating the same process again and again.
After certain tries, the car started charging ( I can see the green battery sign blinking) and all errors are gone(not the replace hybrid battery warning).
The high voltage battery definitely needs some repair, I get 17-21 km range in summer and 10-12 in winter but not sure why it happened all of a sudden ( probably a temperature issue as it was -4 when the issue happened )
16PanaHybrid (12-15-2022)
