Brake kit Question
Brake kit Question
So I am looking to replace the rear Rotors and Brakes on my 14 Panamera as I'm getting a shaking when braking. I just replaced the front and it was not the issue, I am looking at FCP Euros brake kit and I see that they're including a anti rattle clip set and a pad shim. Do I really need these? I saw in most videos they do not replace these items.
It depends. If hearing yiur brakes squeal on your $100k+ car is acceptable, then I suppose you can cut corners and save a few pennies by re-using parts that were designed o be consumable.
digs (05-15-2022)
It's not often that the rear rotors contribute to shaking when braking, but possible. Did you noticed improvements when you changed the front? Shaking reduced or the same? I'm suspecting bushings
