PASM Chassis System Failure
8th Gear
I've a brand new 2022 Panamera 4S, with 2300 miles on it developed a "Chassis System Failure". It's been at the dealer now for 4 weeks, and they still can't find the problem. Any other experiences with Panamera PASM failures?
Chassis system failure message is pretty common, if you search you'll find lots of info.
Many times the message will intermittent, it may not come back next key cycle. Regardless, if the message came up in the combimeter then a DTC was stored - a dealer with PIWIS should be able to read either as current or history codes and have some idea what part of the system was malfunctioning at the time the code was set.
Usually it comes up when air springs are leaky and the compressor can't keep up (to keep the vehicle level at target ride height).
But any number of other items can lead to the message, such as (in approximate decreasing order of likelihood) a NG valve block, NG compressor, NG relay, cracked air line, etc.
Are you sure the dealer can't find the problem, or is it possible they are just doing a poor job of communicating (maybe they are waiting for a part or something)?
8th Gear
Dealer has been excellent at communicating, with at least 1x daily updates. It called out a sensor to start. They replaced that, fault remained. Then they replaced the control module, as that was the next part called for. This had to be air-shipped from Germany. They installed it and the fault continued. So they know have disassembled the wiring harness and are OHMing every wire to look for a short. Several days, no short found.
Today, they actually put a new control module on from another car. The fault went away, but they determined that the part came from another Panamera without the air suspension system, so they aren't sure if it would fault or not.
I had the chassis failure when my alternator failed. Once they replaced it, everything returned to normal and PASM started working properly again.
6000 miles dealer replaced the compressor
8000 miles dealer replaced a broken accelerator sensor on front wheel
Last week 8800 miles, the chassis fault error appeared again…
Sounds like many things can trigger the Chassis fault error. I've had the error due to leaky front shocks, bad compressor, bad ABS sensor, and moisture in the airline. Not terribly uncommon in older Panamera's but seems pretty unusual on a newer one. I have a 2010 Turbo. I wouldn't expect those issues on a newer Panamera.
