Panamera 2010-Current
Trickle charing
Old Jan 10, 2022 | 05:22 PM
Shuga's Avatar
Shuga
Default Trickle charing
It's getting cold here and I don't drive my Panny all the time. I want to trickle charge it. My garage is heated but poorly heated. I have a
NOCO GENIUS5 5, but my question is do I hit 12v or 12vagm? I believe 12v would be fine correct?
Old Jan 10, 2022 | 06:11 PM
knowspin's Avatar
knowspin
It depends, if you have a regular flooded battery then the 12V setting is perfect. If you have an AGM battery, then use that setting.
Old Jan 10, 2022 | 06:23 PM
Shuga's Avatar
Shuga
How would I know?
Old Jan 10, 2022 | 07:00 PM
dudecs's Avatar
dudecs
Originally Posted by Shuga
How would I know?
Check the label on top of your battery. It should be AGM to support the Auto Engine Start/Stop feature.
Old Jan 11, 2022 | 05:08 AM
sp3000's Avatar
sp3000
Most probably you have AGM. AGM likes to charge at 14.7V especially in the cold. Regular lead/acid likes 14.4V, The NOCO will drop down to float (13.3V) when the battery is full.
Old Jan 11, 2022 | 01:24 PM
Shuga's Avatar
Shuga
So if I have AGM I just hit the AGM setting on my NOCO and it'll be good?
Old Jan 12, 2022 | 01:23 PM
JPhi1618's Avatar
JPhi1618
Yes, just set for AGM and it will automatically switch to float/maintenance mode for storage once the battery is fully charged.
Old Jan 16, 2022 | 06:57 PM
Shuga's Avatar
Shuga
How do I know if it's AGM or not?
Old Jan 17, 2022 | 01:30 PM
Shuga's Avatar
Shuga
Anyone?
Old Jan 17, 2022 | 01:48 PM
estrov's Avatar
estrov
Behind the connector it should say AGM
Old Jan 17, 2022 | 05:28 PM
Shuga's Avatar
Shuga
Thank you, I was able to peak behind it and see that It does In fact say AGM
