FS: Cargraphic Lowering Module for 971
New car is arriving soon so this has to go.
Used for 2 1/2 years, ready for a new home. All packaged and ready to ship.
Brand new $1445USD, selling for $945USD shipped.
https://roadsportsupply.com/cargraph...le-971-models/
Electronic Suspension Lowering Module
- for Porsche 971 Panamera with Air Suspension
Including "Plug and Play" adapter option
Front axle: -30mm lower (+/- 20mm)
Rear axle: -20mm lower (+/- 20mm)
Cargraphic electronic lowering modules are designed for
cars with OEM air suspension systems. The electronic
lowering module allows a suspension lowering of up to
40mm / 30mm (+/- 20mm) from the stock setting, which
improves the appearance of the vehicle and reduces the
centre of gravity for improved handling. The original height
adjustment switch and functionality are retained, and
many electronic lowering modules feature plug and play
installation with no wire cutting / splicing required. The
electronic lowering module comes with all necessary
mounting components as well as detailed instructions.
Product Advantages:
- Electronic lowering module with all necessary connectors
- Retains OE suspension geometry and suspension modes
- Easy to install / remove
- Some applications available with "plug and play" adapter
- TÜV approval
- OBD and EMC compliant
Price Net Export: 11571L
Part No: 115P71L
Product Advantages:
- TÜV approval
Part No: 115P71L
Do you by chance still have this lowering module for sale? I very recently bought an '18 Panamera Turbo Sport Turismo and would like to lower it a bit. Josh
healthnut76 (01-08-2023)
