Panamera 2010-Current
Disassembly HV battery pack from Panamera S Hybrid.
Old 04-28-2021 | 05:12 PM
Robe wh's Avatar
Robe wh
7th Gear
Default Disassembly HV battery pack from Panamera S Hybrid.
Can someone share a guidline how to take out the HV NiMH battery pack from panamera s hybrid 2011, and installing back.
Edit
Old 05-03-2021 | 12:01 AM
sunnyc123abc's Avatar
sunnyc123abc
Here you go. Why are you changing the battery? Just curious, I have the same battery in mine.
The following 2 users liked this post by sunnyc123abc:
Robe wh (05-03-2021), sac02 (01-04-2022)
Old 05-03-2021 | 03:47 AM
Robe wh's Avatar
Robe wh
7th Gear
Hi Sunny,
Thanks for the document.
Yes the mpg has been degraded a lot plane to purchase the battery pack from China. But they asked me to take pictures bcos their pack is 2012, and mine is 2011.
Hopefully it is the same. if it not then I have to: purchase battery cell and replace the bad one as showed in Youtube everywhere.
Thanks for sharing the DIY document.
Old 05-03-2021 | 06:28 AM
sunnyc123abc
Could you link me to the China battery and YouTube for changing cells? Mine discharges really fast now.
Porsche has a 8 year 100k mile warranty on the hybrid battery. I was over miles and year but was able to get them to do a goodwill warranty. They checked out the car and said they battery wasn’t bad enough for them to change it.
BUZO JOE (05-03-2021)
Old 05-03-2021 | 07:17 AM
BUZO JOE's Avatar
BUZO JOE
Thanks for posting this helpful doc. On the subject of 8yr battery warranty, is that all year models? My 2015 Panamera S hybrid just went past the CPO warranty at 6yrs. Is the battery actually covered 2 more years? I didn't hear the dealer mention this when I had it serviced just before losing the 6yr warranty.
I'm concerned because I took it for service after two battery related cooling pump codes popped up. Dealer cleared them and was unable to recreate them.
Old 05-03-2021 | 03:47 PM
Robe wh's Avatar
Robe wh
7th Gear
Sunny,
​​​​​​I am currently still chatting with seller as in this aliexpress it does not say for panamera but for cayenne.
pls see the link https://a.aliexpress.com/_m0CbDpT
but since you are in the U.S. there is another shop can do recondition and sell in exchange with old one https://www.acehybridgroup.com/porsche-all-hybrids
or https://hybridbatteryrepairsandiego....e-product.html
in youtube a lot of resources how to replace the cell.. I assume panamera also use prismatic type of cell 7.2V x 40 set (same as Prius gen 2 above)
you can also buy the cell in aliexpress (assuming it is the same, I havent really confirmed yet, this just assumption now, only after I open the Hybrid pack then I can confirm my theory)
​​​​​ NASTIMA Battery Cell Module for Toyota Prius 2nd & 3rd Gen Lexus CT200H Corolla, Levin Lexus ES300H Camry XV40 Hybrid Battery
https://a.aliexpress.com/_mssBlxr
hope it helps
cbwinters01 (05-04-2021)
Old 05-03-2021 | 03:49 PM
sunnyc123abc
Buzo Joe, I believe you are covered.
https://www.porschefremont.com/porsc...anty-coverage/
Old 05-04-2021 | 05:45 AM
sunnyc123abc
Thanks for the info. The aliexpress is a good find. I wonder if its possible to change the battery pack to lithium.
Old 05-04-2021 | 01:19 PM
Robe wh's Avatar
Robe wh
7th Gear
Interesting how would you change into lithium, when the charging system all for NiMH.
Lithium is prone for explotion when to much current or over heat. (this reffer to the theory of Lithium battery vs NiMH)
NiMH is safer but prone to fail or degrade...
anyway if you find a solution how to upgrade to Lithium, kindly share the reference.
thanks,
Old 05-05-2021 | 04:16 AM
sunnyc123abc
thanks,
I’m not that knowledgeable with electronics, didn’t think about the charging part. I’m definitely interesting in changing out the cells if it can be done.
Ive also was looking into reconditioning the NiMH battery pack by fully charging it to 100% then discharging it with a grid charger.
Old 10-30-2021 | 12:32 AM
chine61's Avatar
chine61
2nd Gear
Hi Sunny,
Hi I just got the park safely warning. Replaced the 12v battery thinking that would fix the problem but it didn't. Mine is a 2014 with 20k miles here in mexico they have none experience with hybrids at the dealer so I'm trying to figure out how people fixed the park safely thing.
It was working fine next day didn't want to work. I don't know what to do or where to begin.
thanks
Old 10-30-2021 | 12:39 AM
sunnyc123abc
In California there is a hybrid warranty of 8 years or 100k miles. I dunno if that is available in Mexico.
Old 12-29-2021 | 09:54 PM
peterb77's Avatar
peterb77
thanks,
Good point I should have put a big warning at the start of this topic that PHEV battery systems (even depleted) are High Voltage (technically mid voltage) & High Energy so the message to all is...
Even small electrical currents (100ma) that manage to make it across the heart can cause cardiac fibrillation and kill you
Higher voltages and currents can injure and kill you in much more convulsive and crispy ways
A big risk with working on these battery systems is the risk of explosion and lack of understanding of how easy it is to short these systems causing explosion and melting your face off
Check YouTube for videos of single cells exploding into a 2000c fireball after been shorted then imagine that times 104 cells.... it will melt your face off
This thread is specific to 2014 and later e-hybrids for people not covered by the California 8 year warranty
Panamera E-Hybrids 2012-13 are NiMH, 2014 and later are Li-Ion NMC. Lithium and NiMH cells are not interchangeable because of their battery specific charge and load systems. Even Li-Ion cells have chemistries that are specific to their charge and load systems...... You can (very) easily explode lithium cells with the wrong charge rating i.e. a cell with a 0.5C rate will explode quickly if you attempt to charge it a 5C rate
Old 01-10-2022 | 05:44 PM
amphicar770's Avatar
amphicar770
Important points.
I was speaking with my son who has several advanced degrees in electrical engineering. While I rarely understand half of what he is saying, he was very clear about the explosion risks without proper equipment and knowledge.
I have personally see the aftermath of a 12v regular car battery that exploded (fortunately as a 2nd hand witness after the fact). I imagine one of these blowing up is the nuclear version of that.
Old 03-21-2023 | 10:01 PM
jhayden's Avatar
jhayden
5th Gear
How were you able to obtain a goodwill warranty? my car has 55K miles and the warranty expired 8 months ago, would love any advice on the matter
Quick Reply: Disassembly HV battery pack from Panamera S Hybrid.
