Panamera 2010-Current
Just bought 2018 4s Panamera ... first Porsche help with basics ?
Old 03-15-2021 | 11:34 AM
Mfnoel's Avatar
Mfnoel
1. Make sure you have all your settings as desired (interior temperature zones, seats, etc), set the key button below the 1 and 2 presets with the key fob you use in your pocket / in the car. Maybe try having auto start stop in the off position before setting... this might solve number 3? Not sure, haven’t tried myself.
2. Easiest way would be to get a dummy clip. But why drive without a seat belt? Reason I’ve used a dummy clip is with a different vehicle when using a harness on track.
3. Try above. Alternative is to just switch into Sport mode which disables auto s/s. I have a high driveway curb so my diamond is set to raising the vehicle, so haven’t tried to see if that works... but seems to be an option for some folks but not others.
Old 04-11-2021 | 07:53 AM
Wolfpackdad56's Avatar
Wolfpackdad56
7th Gear
I have the same feeling about the auto stop. I bought 3018 Panamera as well. You can program the ride for individual mode. You can select it as being off. Then all you have to do is push the individual button on the console when you start the car and it won’t auto turn off
Old 04-11-2021 | 11:48 AM
B Russ's Avatar
B Russ
Get this, https://t-design9.com/memory_module_porsche.html I can personally confirm it works perfectly on my 18 Pan Turbo. It took me under 15 minutes to install in both my 971 and 991
The following 2 users liked this post by B Russ:
911sccab (04-12-2021), mustmax (05-08-2021)
Old 05-08-2021 | 12:05 PM
mustmax's Avatar
mustmax
I agree. This is the “right way” to solve your problem. So so easy to install.
Old 05-10-2021 | 01:03 PM
Mfnoel's Avatar
Mfnoel
How long have you had this installed? Quality of the website makes me a bit concerned about the quality of the product…
Old 05-10-2021 | 01:06 PM
mustmax's Avatar
mustmax
I've had mine well over a year and it has been flawless.
Old 05-10-2021 | 01:07 PM
B Russ's Avatar
B Russ
A year on my Pan and 6 months on my 991.2. Go for it
Quick Reply: Just bought 2018 4s Panamera ... first Porsche help with basics ?
