Panamera 2010-Current
Multifunction display
Old Sep 17, 2020 | 11:10 AM
delray993tt's Avatar
delray993tt
Default Multifunction display
I want turbo boost to be on bottom line of display. I can get it to show there but as soon as I turn the car off it goes back to the top line. I can’t see it when it’s on the top line because I like my steering wheel lower and it’s in the way.
Old Sep 17, 2020 | 12:31 PM
Chris51080's Avatar
Chris51080
The settings are probably saved to your key.
Try putting it where you want it, then saving the seat memory.
You may have to go through PCM to ensure its properly tied to the key...its been a few years since I had to sort that out on my PTT.
Old Sep 18, 2020 | 02:13 PM
krabman's Avatar
krabman
Set it the way you want it, save to both the key and the memory position, shut off the car and lock it. Lock it even if it's in your garage. That usually works but also be aware that you can get into a dualing fob situation when your significant other has the second fob on her person, in a purse, etc. The sctive fob is the one it detects first,.
