Brand new Panamera owner, and I’m still reading and learning about everything this car is capable of.
I think I have all the settings set the correct way, but the passenger side (right) mirror still does not tilt down when I go into reverse.
Put it in reverse then set the mirror to where you want it.
I believe when I set my mirror tilt, I simply checked the box, put it in reverse, and set the mirror location. No need to save it to memory.
Interesting I had to on mine or it wouldn't remember it. But, before i saved it, sometimes it would drop, but rarely.?? Seems to be stable now though, so I put it down to saving the memory.
Also same on ambient lighting, wouldn't remember the setting until i saved it to the key.
Huh, I checked the box and mine went down when put in reverse, too far down. I had no idea it was adjustable. I'm going to have to try adjusting it and see what happens, my experience is the car doesn't save anything unless you hit the buttons and possibly not even then.
