GARMIN Parking Cable INstallation HELP
Hi All,
Anyone of you has installed it?
I want to install it for the rear camera (Trunk)...which I believe is an easier spot.
If you could help
Thank you,
Max
If you could help
Thank you,
Max
I've installed it for my front Garmin dashcam in my 2016 4S.
What questions do you have?
I installed mine with a couple of fuse taps - you need ground, one for power when ignition is on (switched), and one for power when ignition is off (constant).
I'm not sure how to do that simply without fuses nearby. Are there any fuses in the back compartment of the Panamera?
It's not exactly helpful, but here's the documentation: https://www8.garmin.com/manuals/webh...3DD3B3F3B.html
Good luck. Fuse taps are cheap, and a multimeter will come in handy as you test for a switched and constant fuse source.
