Panamera 2011 3.0d Tiptronic Transmission Fault
Hello everyone
I have a 2011 Porsche Panamera 3.0 diesel
in my workshop and I'm having transmission issues.
Car runs fine no problem last year happened 3-4 times , I drove the car 1 hour then I turned off after 10 minutes when I jumped started it , the gear selector won't move from park. I got 3 errors on dashboard. Check Engine light , ESP and Start Stop error.
Did a whole gateway scan with diagnostic while it didn't moved from park , only in engine ecu and abs Shows 2 faults , in transmission it won't connect, after 1 hour of rest car got out of park and the diagnostic tool connected to transmission ecu but it didn't show any fault code on transmission.
Checked all the wiring from engine ecu transmission and inside car gearbox ecu all seem okay no corrosion
Need serious help here.
Here are two fault codes in DME and ABS , no comunicating with transmission when stuck in park , when it works fine it comunicates but shows no errors
