ctek 7002 maintainer
Does anyone know if i can attach the ctek 7002 to the 2015 Pamam gts under front hood battery posts in "supply" mode while i unhook and replace the battery in the trunk.
Will this maintain the car's memory settings or should i attach to battery cables instead?
If there are no large currents draws that should work. I would ensure the trunk light is disabled before disconnecting the battery.
