Interior trim install
I am in the process of swapping out my piano black interior trim in my 2013 GTS. I have swapped the doors and the rear console with no issues.
My problem is the front center console....
I have seen that I have to remove the PCM to swap the console trim piece. That also requires removing the center vents. From what I have read
that may be above my level of skill.
It also appears that there are components that attach to the center console trim from below.
Has anyone done this? I have searched youtube and found very little of any use.
Any advice, suggestions, etc. would be greatly appreciated.
Thanks,
Also, when I am done I will have a complete set (14 pieces) of piano black trim available for sale....
I did this on my Cayenne (I know different but similar) and you had to remove the dash pieces where the front corners of the console meet the dash then remove the shift **** and there was enough space to pull the center console up from the rear although there might be some bolts in the cup holder area as there were underneath the Cayenne ash tray (in front of the gear ****).
Good luck and let me know how it goes as I'm thinking of doing the same, what finish did you choose to replace the pano black?
Nice!
Following. That stuff is super glare. What material do you intend to swap it with, and where'd you get the part(s)?
