DIY: Panamera fuel filler door & hinge replacement
This is not with actual pictures, but this is the process. Instead of hook tool, you can use one of those small metal paint can opener hook tools, will work same way for you.
Hope it helps.
PRELIMINARY WORK:
REPLACING FLAP AND HINGE:
Hope it helps.
PRELIMINARY WORK:
