Panamera 2010-Current
SatNav Walkabouts...Again
Old Nov 19, 2018 | 06:00 AM
ajriches01's Avatar
ajriches01
Default SatNav Walkabouts...Again
Some of you will remember this was a problem for a LONG time, which seemed to have been fixed after they replaced the PCM, nav module and about everything else apart from the wiring. Coming home from Heathrow she started to go for a wander across to the field on the opposite side of the road. Has this issue been fixed for others and was there an identified common fault?
Thanks!
Alex
