Panamera 2010-Current
Climate Control Problem
Old Nov 7, 2018 | 08:31 AM
ajriches01's Avatar
ajriches01
Default Climate Control Problem
Hi All
Has been a while since I posed - have been enjoying the eHybrid (although the GPS STILL goes walk abouts from time to time).
Recently the climate control has been chucking-out cold air regardless of the temperature set. Has anyone else experienced this?
Many thanks
Old Nov 7, 2018 | 09:46 AM
K777's Avatar
K777
No but since it had the GPS antenna done I don't get any blow from the centre vent under the touch screen. Passenger side ok, drivers side theres nowt.
Goes in 22nd for a phone antenna issue (car connect says -58psi in fronts on the phone car shows -1 and average MPG is showing 6mpg over 12k miles car shows 41ish).
I think maybe they havn't connected something correctly when it was stripped.
Maybe same with yours when the dash was stripped ?
Old Nov 7, 2018 | 10:21 AM
ajriches01's Avatar
ajriches01
Could have come loose I guess, but have done circa 3,000 miles since the GPS was "fixed". In fairness, it was fine all the way down to Lake Maggiore and back.
When the car was returned it had an awful rattle which I took back once - no change - then realised it was the side panel to the glove box that needed snapping back into place. Not great.
