Displ. Sensor shift rod gears fault impulse signals 1/3 P1733
Hi,
I have Porsche Panamera Turbo 2012 , it was in good running condition. I drove it home last time and parked in the garage with no issues. Tried to go to work next day morning so I fired her up and immediately got a "Transmission Fault" indicator as well as the check engine indicator. Tried to reverse out of my driveway but no go. It just revved like it was in neutral.
the last diagnose the issue by pulling the fault code(s)
Displ. Sensor rod gears fault impulse signals 2/R P1734
can any one help how to fix these errors?
From all the reading I did researching my car I think his tranny is FUBAR - with that said I think it is also possible to get them rebuilt now as well, Ran across a couple of sites that seems to say they could........
check your battery first - make sure it is good - weird things happen when they get low
it worked for a month without a problem ... after that car start behaving funny .., it sometimes do same ... some times stucked on 2nd shift alone without others R and others ... I have to switch off the car / switch on again until problem disappeared ... and work normally ... but after few days it was doing same on driving stuck on 5th shift and I have to park car and switch off engine and wait for 5 minutes and switch on again so car return back to normal behavior
Hope my description is understandable
Most likely his problem is else where, but you need to eliminate all the variables
