Panamera 2010-Current
Sport mode not available message
Old May 9, 2018 | 01:41 AM
CPanamera4s's Avatar
CPanamera4s
Default Sport mode not available message
Hi all,
2012 pan 4s with about 84k miles. I press sport or sport plus and the message pops in sport mode not available. I have been trying to search online what this relates to but haven't been able to find anything. I could just take it to the shop but wanted to see if anyone would know.
I am able to drive the car on comfort mode but feels little sluggish and short of power. I did push it a little using manual and going up the rpm to see if I could bring out some kind of fault code but nothing .Obd machine doesn't read anything, no warning lights on dash.
Also get a crunching noise when cruising. When this happens the rpm are a little unstable and go down a bit and try to go up. Not sure if this was due to worn out spark plugs which i changed this weekend .haven't taken the car out yet though .
​​​​​​Any feedback on that sport mode ?
Old Oct 4, 2019 | 11:31 PM
Voxx's Avatar
Voxx
Where you able to find a solution to this problem?
Old Oct 5, 2019 | 06:06 AM
Regenwulf's Avatar
Regenwulf
5th Gear
Could be a coil pack.
Old Oct 6, 2019 | 07:41 PM
Paul Rathjen's Avatar
Paul Rathjen
Sounds like limp mode.
Could be many things. What you describe is for sure not normal. I’d take it in for a service check. Could be plugs or coils. Could be electronically off and needing a recalibration. Maybe a fluid change would help. Start simple before you freak out but definitely don’t ignore it.
