Panamera 2010-Current
2013 Panamera horn
Old Apr 24, 2018 | 05:21 PM
pieter97's Avatar
pieter97
Default 2013 Panamera horn
Hello Forum,
Horn is not working, replaced both units / horns, still no beep.
Checked relay, seems to be good. Any suggestions on what to check next?
thank you,
Old Apr 25, 2018 | 12:51 AM
PTEC's Avatar
PTEC
Did you get the new horns from a dealer? The original horns are no longer available and the new horns from Porsche are updated. The connector is the same but it will require you to swap the 2 wires in the connectors to get the new horns to work.
Old Apr 25, 2018 | 01:26 PM
pieter97's Avatar
pieter97
yes, got the horn from Porsche / OEM
2 wires in the connectors... can you elaborate?
thank you!!
Old Apr 27, 2018 | 01:04 AM
PTEC's Avatar
PTEC
thank you!!
They should have sold you 2 adapter harnesses but the truth is you dont need them. There are 2 wires that go to the connector for the horn. The brown wire goes into pin 1 and the purple wire goes into pin 2. Swap them and the horns should start working.
