Panamera air suspension
I have a 2013 Panamera that has experienced its second chassis failure in 3 months. The first failure was in the front. The latest failure is in the rear. Porsche apparently has not made the software to properly diagnosis and repair this problem available to independent shops in San Antonio (or no shop has chosen to purchase it). I want to avoid the dealer in San Antonio as their parts mark-up is 50% over list. I know any repair will be expensive, so I would like to know if there are aftermarket alternative suspension packages that I can install to replace the original factory equipment. My ideal solution would be to replace the factory pneumatic with a less complicated and potentially more reliable system. I have no objection to losing some of the functions that come with the factory system. Any ideas? Thanks!
