RPM flutter at steady speed
I recently picked up a Panamera Turbo, and noticed an odd behavior.
While driving at a steady speed, I can see the tach needle fluttering a bit. Maybe 25-50 rpm, so not a lot of movement.
I can't imagine this is completely normal, any ideas what's going on before I take the car to the dealer?
What year is your turbo?
We have found our 2018 Panamera doing some weird electronic things.
Haven’t noticed what you describe - but it does “surge” at low speeds, like backing into or pulling out of a parking space. Gotta be really careful as we don’t want the car to “surge” into something unexpectedly.
Mine is a 2011.
It's just the tach needle that I see bouncing while at steady speed, the car does not change speed, and there is no jerking, lurching, or any other strange behavior.
I'll update after I have a dealer look at it.
Ours is also doing weird stuff like when we close the trunk (using the button) it stops half way down for no reason. Yesterday it stopped 1/2 way, and then I re-pressed the button and it stopped again about 6” from closing. So I had to open trunk and try again. Second time it closed no issue. The problem is intermittent.
Also sometimes when we turn the dash “key” everything lights up but it doesn’t start. Have to turn the key again. Intermittent problem.
Hubby programmed the “diamond” button as the start/stop defeat - but sometimes even after we press the button to turn off stop/start - the car turns off anyway. Intermittent.
There seem to be electronic gremlins and we are hoping it’s simply a matter of doing an update or refresh. We won’t be bringing it in until March but I’ll report back once they (hopefully) figure it out. We are actually making a LIST of things for them to address as there are several more weird happenings and we figure we won’t remember everything especially since it’s intermittent.
We had a 2015 GTS and it had none of these issues. And was the best sounding car EVER!
Today it decided to stop folding in the mirrors when we lock the car.
Hubby has it configured to always fold in mirrors when locking. Three times in a row we locked the car and mirrors stay out. Twice after unlocking, and another time after we were at a new destination.
Called the dealer. They are making a list. And the trunk did the funky thing stopping half way down again for no reason.
We like the car and hope these gremlins are a matter of a software update or re-boot or something simple.
I've similar problems with my 2018 Panamera 4
1) "All doors Unlock" option doesn't work (looses this setting once the ignition is off)
2) "Mirror fold when lock" option doesn't work (Looses this setting once the ignition is off, means it doesn't work when I step out of the car and lock it)
3) Ignition sometimes doesn't work. got to turn it off/on and it starts
4) Trunk stops halfway when closing (happens sometimes when using the hatch close/lock option)
5) Trunk open foot sensor doesn't work sometimes
6) Transmission is very jerky sometimes in Normal mode
7) Volume mute button both on Steering wheel and on dash doesn't work sometimes
8) Configured the diamond key for Surround View camera and it looses that setting quite often, like every other day
Just checking - when you say closing trunk with button, you mean the one on the trunk itself? Unlike other cars, I've not found a way of closing the trunk with the key or from the driver's seat (annoying!).
On closing the trunk -- on the 2014-2016 models, if you hold the truck raise button on the drivers door panel the hatch will close. You have to hold the button until the hatch fully closes (it's not auto close). I would expect the new model to behave in the same manner.
Regards,
Chuck
14 Panamera 4S
Regards,
Chuck
14 Panamera 4S
Trunk can be closed from the drivers seat but I've to hold the button till is closes.
I have a 2018 4S and when I close the trunk with the button on the left, it closes but when I close the trunk using the right button, it stops halfway. Transmission is very jerky in sports and sports plus but seem to be fine in normal mode. I don't seem to have rest of the problems but I have problems with the dash screens. It turns black whenever I get a call and starts flickering.
