Panamera Turbo - Grease on Rotors
5th Gear
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
I recently acquired a gorgeous 2012 Panamera Turbo - Black on Black. As I was washing it this evening I noticed an odd sheen on the front rotors. The outside surface of the front rotors on both left and right sides had a layer of grease - thick and a bit sticky. Inside of front rotors is totally dry and both sides of rear rotors are dry as well.
I have driven the car almost 1000 miles since I got it 3 weeks ago and have not noticed any issues whatsoever; maybe just a touch of brake squeal at low speed.
I wiped down the rotors with wax & grease remover so we'll see if it comes back. Any ideas on how the rotors could have grease on them?
It was the same on both sides of the car but just the outside surface of the rotors. Very strange.
Any feedback appreciated! Thank you.
Steve Getsiv
Panamera Turbo '12
Steve Getsiv
Panamera Turbo '12
Received 1,225 Likes
Steve Getsiv
Panamera Turbo '12
Steve Getsiv
Panamera Turbo '12
If it comes back, it could be a number of other things, which require a mechanic. Also, just in case check the brake fluid level - if it's low, take it to a mechanic ASAP.
