winter storage - opinions on storage options, methods
Hello - So, this is the second winter I am garaging my Porsche Cayman S. And, well - like many other cars what I do is make sure the tires are always full of air (+3-5 psi) and typically take it for a spin every 2-3 weeks for 8-10 miles if I can.
I also store it with Stabil fuel additive and keep it on a tender, otherwise I noticed that in sub zero my battery dies - learned that last year, haha!
My question is this. This year, I want to change my oil, but I'm wondering - is there any benefit to drain the oil and store the car with no oil in it and put it up on 4 jack stands in my garage and still keep the car on a tender?
Or, does what I'm doing make more sense, exercise the car every once in a while and keep the oil in and stay happy since driving it every once in a while puts a smile on my face!!
I would either drive it more frequently, and take longer trips, or I would leave it in storage on a tender all winter.
Regarding draining the oil and leaving it on jack stands: Seems like a terrible idea. The suspension is designed to carry the weight of the car, not hang in the air for months. I can't understand why you would drain the oil and leave it empty; just do an oil change if needed. Also, you want to go higher than a few PSI over if you are storing the car all winter to avoid flat spots; I recall 50 PSI being mentioned in the 991 forum for storage, which is ~15 lbs over.
I drive my 911 all year, so my vote is to get out and drive it more![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
If it's decent/clean out post-storm, I like to take it out every 2 weeks if I can. I keep it on a tender and I keep the tp a bit high, not 15psi high because I'm constantly moving it...
Cheers to the advice - the dry storage without oil was just something dumb and you also helped confirm for me that suspension shouldn't just hang there.
BUT, what do these classic car people do when they store their cars? Are they just putting tons of air in their tires or what goes on? I'm so curious as I want to get into auctions and collecting. Have a great weekend!
Technical Guru
Does what I'm doing make more sense, exercise the car every once in a while and keep the oil in and stay happy since driving it every once in a while puts a smile on my face!!
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
You are damned if you do and damned if you don't. Pick your poison; in an unheated garage you'll end up with condensation and then water collecting in your oil (from not getting the oil above 212F) or corrosion pitting on your camshafts from not running it for months on end.
