Reverse mirror tilt pointing up rather than down? Also faux key query
Wanted to know if this was proper behavior in the Macan? On all my bmw the mirrors would tilt downward towards the pavement. However my mirror tilts upwards. Not sure if I have an incorrect setting. Also I would like to remove the faux key for entry and drive and found online I am supposed to hold it to the left but a light twist to the left and putting pressure to the left doesn't seem to disengage the key from the slot. I have held it for a solid 30 seconds and nothing appears to happen.
Video of my mirror issue
https://goo.gl/photos/CTJ9VKUURs5B3UeMA
Go into the settings menu and reverse options will let you set the reverse mirror correctly. Mine was delivered the same way with the mirror tilting up when engaging reverse.
If it's anything like my Boxster, the angle the mirror takes when you use that feature is configurable and tied to the key memory settings. I believe if you turn on the feature, put it in reverse, and then set it where you want it and save the settings, it should then remember it and go back there in the future.
Wanted to know if this was proper behavior in the Macan? On all my bmw the mirrors would tilt downward towards the pavement. However my mirror tilts upwards. Not sure if I have an incorrect setting. Also I would like to remove the faux key for entry and drive and found online I am supposed to hold it to the left but a light twist to the left and putting pressure to the left doesn't seem to disengage the key from the slot. I have held it for a solid 30 seconds and nothing appears to happen. Video of my mirror issue https://goo.gl/photos/CTJ9VKUURs5B3UeMA
