Porsche Macan S/Turbo Electronic Lowering Module by H&R In Stock
To get a drop out of your Macan with air suspension, your going to need a lowering module. H&R has your answer.Designed for cars with OEM air suspension systems, the electronic lowering module allows a suspension lowering of up to 40mm from the stock setting, which improves the appearance of the vehicle and reduces the centre of gravity for improved handling. The original height adjustment switch and functionality are retained.
H&R states a 1.5 inch drop in the front and the rear.
I would say kinda "plug and play". Not quite as simple as plug in and forget about it. At least with the Cayenne it was not that simple. I will reach out to H&R about this.
