AS/PASM or PTV plus
There isn't a better performance option on this car than AS, based on my testing out all of them thus resulting viewpoint. I don't need a driving instructor to want the best suspension capability and flattest cornering available on my car. My Macan needs to do lots of things at once for me, that's the "performance" I seek. And the AS is paramount to that. Not to mention that sweet stance on Pyramids car.
I actually agree with you on the looks with it being a bit lower but I may say the PTV may have been as good of a performance option. If you are going to say that AS is the best, please back that up with fact. I may even go out and say the 3.6 liter may be a better performance option followed by bigger brakes. A good driving instructor will help you be able to get the maximum out of the build you spent your money on. just becouse you installed the parts does not mean you will be able to get the proper performance out of it. A plus, you seemed to like your dealer track day, I believe you would love a couple of PCA track days.
The Air Suspension for me is the must tick option on the car (as well as 3 zone climate) as it allows you to lower the car improving handling, braking and fuel economy. The car sits .6 of an inch lower than the steel car normally and then 1 inch lower with the low level engaged. The off road setting gives you better ground clearance with a ride height of 1 inch higher than the steel springs, the lower sportier setting gives you the best handling version of the car and the standard setting rides much nicer than the standard springs.
I am close to getting nailing down my build and would like to hear your thoughts on this.
I am getting an S and will not be doing any off-roading.
Trying to keep things reasonable, I am debating if one or both of these options are worth it. My main goal would be to maintain the driving experience that I have come to love with my 911S (which will soon be turned in at lease end).
By the way my 911 has neither the PASM nor PTV.
Thanks for any insight.
I need an "SUV" (in quotes because I don't consider the Macan a full fledged SUV) because the cabin space itself has a vertical dimension I require. Not to mention the ONLY "SUV" I'd buy is a Macan, as it really is the "SUV for guys who hate SUV's" as a magazine article said. But I don't find many redeeming qualities of a high riding car otherwise. So getting it as low as possible without messing with suspension geometry (i.e AS on the Macan) is the closest I can get to having my cake and eating it too. Plus, it's probably the best AS system I've experienced yet (thanks in part to PASM being mated to it and how they interact with each other), in maximizing sporty performance and comfort at the same time, and of course there's always the off road benefits if you ever need that.
There is really no need to add AS. If you plan to keep the car for a certain amount of time, beyond warranty, AS will be a pain in the *** to fix.
PASM and PTV is more than adequate. Save the money for something else. Getting better tires already over come the AS performance factor.
There is really no need to add AS. If you plan to keep the car for a certain amount of time, beyond warranty, AS will be a pain in the *** to fix. PASM and PTV is more than adequate. Save the money for something else. Getting better tires already over come the AS performance factor.
1. While 'normal' driving will feel very similar with all 3 suspensions, the REALLY bad roads and bumps are significantly softer with the air suspension.
2. When in 'sport plus' mode, not only are the shock absorbers stiffer, but the car is lowered giving it a lower center of gravity, but most importantly: the actual alignment and suspension geometry changes. Ask any track guy on here how much a difference the amount of negative camber makes on a cars handling- It is a *drastic* difference in performance, and feels like a completely different car. If you plan to do any "spirited" driving at all, the $2800 is worth it.
Lasty, I do NOT believe PTV to be worth it, unless you are either an a. VERY advanced driver that plans to push the vehicle to its handling limits, or b. Willing to pay a premium for the latest and greatest technology, even though it may not make a noticeable difference in day to day driving. If you are not getting the air suspension, PTV is almost completely useless, unless you plan to disable the stability control and go hooning**
** Hooning v. See video:
I'm glad it's not standard. Don't need it and would rather it not be built into MSRP. I love the enthusiast centric a'la carte optioning strategy. I wish Rear Seat Heaters weren't included in premium package either, as it's just "dead weight". Only thing it's done so far is impress my future mother in law and allowed for one time use. I doubt it'll get much more mileage than that as I rarely if ever have rear seat passengers.
All- thanks for the replys. As usual, lots of good stuff to think about/consider.
In the end I just went with the PASM without the AS or PTV.
We'll see how that works out; car scheduled to be here in early May and I have to say am kind of excited about it although it will be sad to say goodbye to my sweet 991 S Cab. Hands down the best car I have ever owned/driven.
I am consoling myself with the prospect of looking for the perfect '88-89 Carrera to fill the 911 void.
